Home > Puma (Tdci) > Puma central locking fault |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 515 |
Not got any real experience of fault you are describing but I'd try and check the remote with one of those detectors that you can get to make sure it's not continually transmitting when pressed...
But More likely a poor connection that is not recognising the lock and unlock status... Long process but maybe go round checking the connectors on the doors If nothing else it gives your thread a bump👍😁 |
9th Oct 2023 8:05am |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1076 |
Me too The only lock state sensor is a switch in the driver's door. So you could unplug the driver door's wiring and see if the fault is gone. Rotten/seized door locking mechanics isn't uncommon https://www.defender2.net/forum/topic86667...ar+wiring.
9th Oct 2023 10:07am |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1782 |
Sounds like the mechanism is 'bouncing'.
Try sitting inside and apply little finger pressure on the locking button when you set the locks, if it works then you can hopefully just adjust the locking rods inside the door. (easier to do than explain...!) HTH Keith |
9th Oct 2023 11:42am |
holascin Member Since: 02 Jul 2020 Location: Worcestershire Posts: 2 |
Thanks for the replies so far. I'll take a look at the weekend and report back 👍
11th Oct 2023 6:22pm |
