Home > Faults & Fixes (L663) > D250 Engine Oil Leak |
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 77 |
Diesel engine oil will stain everywhere, it's so thin and black. Looks like the turbo oil feed line or fitting is leaking. Any oil underneath the vehicle? That could suggest turbo main bearing seal...
1st May 2024 9:44am |
ddg333666 Member Since: 08 Dec 2021 Location: Sydney Posts: 8 |
Luckily no oil underneath , JLR return the vehicle and advised turbo oil feed was loose, let's see if happens again . Thanks for the reply
2nd May 2024 7:50am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2281 |
The turbo oil feed pipe has always had slight leak on my D250, l've looked at two others and they were the same.
l would take it back to the dealer, but in my experience they usually make things worse, plus the last time it went in for a recall it came back with scratches from shoddy valeting. |
2nd May 2024 7:13pm |
