Home > Off Topic > compressors |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 332 |
After over 15 years using various Budget 50 litre ones for my work I upgraded to a 100l Wolf twin cylinder with a belt. All I’ll say is that I wish I’d bought one year’s ago. It’s much much quieter for a start and has enough capacity to spray paint. It will run a DA Sander, but not for long. I think I paid around £350 five years ago, but would be a bit more now. It will operate on 13 amp plug, but I fitted a 16 amp as I’ve got the larger ( cooker ? ) cable already fitted when I had my workshop wired. This stops it blowing fuses when under load. Hope this helps.
28th Apr 2024 8:46pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16941 |
It rather depends what the air tools you want to run are, and how long you want to run them. On the whole, get the largest CFM you can, you will always want more air rather than less.
28th Apr 2024 9:24pm |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1190 |
3hp motor connected with a belt to the twin cylinder compressor with a 200l tank. It was free so not complaining.
Been managing to keep up with me spray limewashing the house today. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
28th Apr 2024 9:44pm |
julian Member Since: 17 Feb 2017 Location: Devon Posts: 57 |
I have a pair of 3hp 1ph units here. One is direct drive and the other belt drive.
My advice would be to make certain you get a belt driven unit. |
29th Apr 2024 2:52am |
