- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Diendien
Hi everyone. My 2.2 puma is vibrating badly at around 110km/h. Only vibrates when accelerator is released with a cracking sound through the chassis. Steering is stable and everything looks fastened. Can anyone assist as to what could be going on?
Kind regards
28th Apr 2024 10:48am |
Ianh
It could be many things, but easy things to check for play are props, their universal joints and flanges where they connect to the front and rear differentials and transfer case.
Also check the front diff for carrier wear as the hole in the diff carrier for the cross-pin can elongate.
https://www.defender2.net/forum/topic79126.html
28th Apr 2024 11:38am |
