Home > V8 P525 Area (L663) > V8 Exhaust Rattle |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19657 |
Would an aftermarket option be possible? Failing that, probably best to deal with a LR dealer directly, and seeing as I presume it’s new, they owe you answers until it is right.
Without going into great depth, is there any close alignment of the exhaust to another part or any loose heat shield or anything? In the vicinity that might cause the resonating behaviour of the exhaust. It could be an internal baffle that is rattling, and if that is the case I might suggest it is a manufacturing issue. Hope you find a solution. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
26th Apr 2024 8:28pm |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 251 |
Mine doesn’t make this noise. There has been some history with other variants where heat shields have caused this sort of noise.
27th Apr 2024 12:45pm |
