Home > Technical > Defender TD5 Grinding noise when turning slightly left VIDEO |
charliebroom Member Since: 16 Feb 2021 Location: Cheshire Posts: 7 |
Hi,
My Defender TD5 has a grinding/whirring noise when turning slightly left (Nothing when turning right) it sounds like a stone caught between something and stops when on full lock or with the wheel straight... Only happens at 5-15MPH then goes, I can see anyting grinding and it dosn't do it when stationary, heres a video, the audio isnt great. https://youtube.com/shorts/sEa-7jRWYUI |
25th Apr 2024 3:04pm |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 132 |
The easiest first check is to take the cap off the drive member and check the CV joint splines are greased. If rusty, they can grind and bind as they move in and out when turning LR Workshop
Find a Defender's history and spec: https://defender.lrworkshop.com |
25th Apr 2024 8:13pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5428 |
Check for debris stuck between brake disc/brake calliper/disc back plate.
26th Apr 2024 5:15am |
