Home > Puma (Tdci) > Intermittent speedo problems 2009 Puma 90 pickup
Philbr110
Hi all, Looking for some help on how to resolve an intermittent problem with the speedo / instrument cluster.
When starting the engine the speedo jumps erratically and acts like a rev counter as you press the accelerator. When driving, if the problem occurs, engine power is momentarily cut as the speedo needle jumps around.
I have replaced the speed sensor / pick up at the gearbox but no improvement.
I also added a dedicated earth cable to the gearbox casing, again no improvement.
I removed the instrument cluster, cleaned the plug & pins.... no improvement.
I have a video that shows what is going on if this helps.
I have searched google for hours and cant find any other tips.
Any ideas?
Thanks !
Post #1032653 24th Apr 2024 11:57am
