Home > General & Technical (L663) > Fault after enabling dynamic with G4 |
Looneyfitter Member Since: 03 Mar 2024 Location: Liverpool Posts: 26 |
Click image to enlarge These are the 3 changes I made. Cheers. Click image to enlarge Click image to enlarge |
20th Apr 2024 8:42pm |
aquascape Member Since: 08 Mar 2023 Location: Sutton Coldfield Posts: 200 |
Dynamic Mode settings
EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode" EUCD-245 Dynamic-I Standard: Dynamic-i Not Fitted Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen MultiCAN-562 DynamicProgMode Standard: Not available for selection Changed to: Available for selection without timeout Other possible value: Available for selection with timeout MultiCAN-605 ConfigDynamicMode Standard: Not Fitted Changed to: Fitted MultiCAN-777 Ter Dyn Select In FCPB Standard: Control interface not available in FCPB Changed to: Rotary used for selection within touch screen EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode" MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar |
20th Apr 2024 9:43pm |
Ah OK mate thanks. So there's more codes to address?
20th Apr 2024 10:23pm |
I think you may of only half enabled it. Need to reboot pivi afterwards and lock and leave car to sleep 15mins min MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
20th Apr 2024 10:41pm |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 375 |
I also set: Multican 682 DynamicLiteMode to Available for selection whitout timeout. No Mud flaps for my 90.!
----------------------------------------- P300 S MY21 on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
21st Apr 2024 8:36am |
OK so added the missing codes this morning. I can now select terrain response but I still have the i on the dash.
I had a message pop up on the screen saying start/stop button fault detected. I have run fault finding and this is the only fault I have? I did enable WiFi hot-spot too yesterday. Wondering if. It could be that? Click image to enlarge |
21st Apr 2024 10:35am |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 131 |
hi, this error doesn't seem indicative of a problem on bcm,
Does the error remain even after the machine sleeps? personally I would restore the original configuration, then possibly try to make one change at a time. Marco Click image to enlarge |
21st Apr 2024 8:32pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2557 |
All the changes I have applied have taken several ignition and sleep cycles to start work properly and all have created error messages to begin with. I think it takes a day or two for all the ECUs to learn the new CCF and before that happens it can generate errors.
21st Apr 2024 8:42pm |
Thanks for the input guys. All is OK now. After a few resets it went away. The i with a circle was because I was low on fuel lol
21st Apr 2024 10:00pm |
