Home > In Car Electronics > TD5 Console Conversion
TheBritBrick
I am looking for information/knowledge on parts and possible options. I have a 1997 300TDI that I am looking to upgrade the interior on, I want to do a TD5 double din conversion. Can buy any of the parts needed for the conversion new or where is a good place to get used one. I know you can get a TD5 double din face plate from MUD but other than that I have seen any other parts. I'm also looking for a spare lower dash and up dash panels.
Post #1032155 19th Apr 2024 4:23pm
Linds Hanson
SP panels do a facelift TD5 type dash conversion
Post #1032172 19th Apr 2024 7:27pm
Check out Mudstuff.co.uk they do what you need.
Post #1032177 19th Apr 2024 7:52pm
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
Fitting the Mud double DIN is fairly straightforward, but obviously requires some dismantling. Take photos as you go just in case.
When I changed the console to the double DIN, I also changed the binnacle Mount, because the original was cracked and barely holding together! Raptor sell a metal binnacle mount that is much stronger than the original plastic one.
Raptor also sell a metal binnacle end plate, but I have no experience of this.
Post #1032181 19th Apr 2024 8:23pm
Linds Hanson
They only do the centre panel the op needs to convert from a early 300tdi dash
Post #1032213 20th Apr 2024 10:10am
