Home > Puma (Tdci) > Speedo needle jumping |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 132 |
I had this problem on the Td5 setup and the wiring had dropped so that it touched the prop shaft and had worn through the wires a bit. I'd be looking for a short somewhere. LR Workshop
Find a Defender's history and spec: https://defender.lrworkshop.com |
15th Apr 2024 2:39pm |
Philbr110 Member Since: 14 Nov 2016 Location: NI Posts: 27 |
Hi, Did you get your problem sorted out?
I have a similar issue that I'm struggling to fix. Thanks Phil |
24th Apr 2024 1:58pm |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 335 |
I just consulted the WSM, the speed sensor is marked yellow. Will have a look later on if that part is present. Could it also be a loose contact in the cable to the cluster? I *think* it's #13, brown/red
Click image to enlarge |
2nd May 2024 8:56am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7711 |
i would suggest most likley a breakage in the speed sensor insert to the t box its a small box section or the wiring to it Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
2nd May 2024 10:04am |
