Home > Technical > LT230 lock lever positioning |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16941 |
There's a photo of a correctly assembled one halfway down this thread:
https://www.defender2.net/forum/post665406.html |
9th Apr 2024 10:49pm |
bitcoin Member Since: 21 Mar 2024 Location: UK Posts: 10 |
Thanks blackwolf
Do you know if this is the same across different years/models of defender? My vertical lever bar is straight, but the one in the thread posted has several links and bends in it. (Just triple checking it’s not different before I start undoing things) |
10th Apr 2024 7:16am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2557 |
There are lots of different lever arrangements depending on age of vehicle and gearbox type.
10th Apr 2024 11:00am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2237 |
Mine is/was 100% definitely to the right of the selector as shown on your photo
I actually refitted it to the left once (as I mention in the below link) as I was following the photo blackwolf has referenced but I could not get diff lock in this configuration so had to disassemble and reassemble again to the right. Works lovely It's not the best setup in my opinion. That 'lever' coming down from the shifter is feeble https://www.defender2.net/forum/topic53240-256.html > 110 XS Double Cab > Instagram @simonlanemind |
10th Apr 2024 11:41am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3218 |
Picture from a Puma 2.4, lever to the right.
Click image to enlarge Picture from my 1988 90, lever to the left. Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
10th Apr 2024 12:26pm |
Interesting stuff. I realise now that the thread I linked to is specifically asking about the TD5, so R380 + LT230 combo, which has a entirely different selector mechanism to the Puma's MT82 + LT230 combo.
The two screenshot below are from the Puma WSM and clearly show the bottom of the selector lever to the offside of the difflock selector link on the transfer box, which I believe is how it should be on a Puma. My apologies if my earlier attempt to be helpful actually had the opposite effect! Click image to enlarge |
10th Apr 2024 2:12pm |
Presumably the gubbins inside is the same, so the difference is just a push me pull you rather than a pull me push you > 110 XS Double Cab
10th Apr 2024 3:49pm |
