Home > In Car Electronics > Land Rover Spot Switch Into Lazer Loom
mcma1
An easy one for the experts on here but how do I get this LR switch into this Laser loom. No headlights, just switch turns on the lamps?
Should I do the following?
Feed pin 5 from 87
Relay/Lamp grounds 86 from pin 1
Ground for switch to pin 4
 Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #1031077 9th Apr 2024 2:29pm
PaulMc
Take "Battery (-VE)" from relay terminal 86, to pin 1 on the switch.
Wire pin 4 on the switch to earth.
Wire pin 2 on the switch to dash illumination.
Run an additional wire from relay terminal 87, to pin 5 on the switch - for the 'tell-tale' illumination.
. Paul.
Post #1031095 9th Apr 2024 6:33pm
mcma1
Post #1031106 9th Apr 2024 8:34pm
mcma1
Sorry Paul 85 to ignition +ve? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1031135 10th Apr 2024 6:31am
Likeomg
Think ill re-wire my switches with this advice,
For my lazer's currently it's on / off but like the idea of them illuminating with dash lights / when the LED bar's are on
Post #1031154 10th Apr 2024 10:34am
PaulMc
Yes Thumbs Up Paul.
Post #1031170 10th Apr 2024 1:17pm
