Home > Off Topic > Compressor cupboard |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3219 |
Like that John
Something that probably will have to do some day in the future for the compressor when I move garageā¦ grumpy neighbors Any concerns for overheating for the compressor? Is it easy to get to drain condensation from the tank? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
5th Apr 2024 8:41pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5745 |
Cheers. No real concerns of over heating, If I do use it a lot I can open the door inbetween the compressor running and as for the drain tap, I can still pull forward/remove the compressor if need be to get to the drain. 1999 Defender TD5 110
6th Apr 2024 8:14am |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4951 |
what compressor do you have? me and my dad are looking at one Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
6th Apr 2024 3:29pm |
Is a Sealey 50 litre - similar to https://www.eurocarparts.com/p/sealey-sa50...d_source=1 1999 Defender TD5 110
6th Apr 2024 4:26pm |
Lightwater Member Since: 28 Jun 2020 Location: Sydney NB Posts: 61 |
Line the enclosure with engine bay acoustic insulation 25mm minimum, double or triple up where you have the space. I have 3 ARB compressors in the car in parallel to pump up tyres quicker, with acoustic insulation stuffed everywhere. It makes a huge difference in lowering noise levels.
Also screw a cross brace or 2 to reduce vibration to the 2 large side panels, like one would with a speaker enclosure. Visitor - Freelander owner |
10th Apr 2024 11:01pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 808 |
Having owned several compressors typically sold because if move and or too little use, I now have one of those quiet Einhell compressors. Absolutely fantastic, I would never buy a standard compressor again!
https://www.toolstation.com/einhell-24l-1h...sor/p93559 |
11th Apr 2024 4:29pm |
