Home > Technical > Headlights |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19658 |
Yes, it’s likely to be the pins on the stalk are burnt out or worn, possibly both.
Do you use a headlight loom such as LandReiziger? If not, then it’s more likely the stalk has its pins burnt out as the current load is higher through the contacts. I’d suggest taking in a look to see what is going on there, if you activate the main beam stalk in the manner that you had the headlights not working then you’ll immediately see the appropriate contacts to look at you can temporarily bypass those contacts for testing purposes and if your main beam headlights then work you’ll know the stalk needs replacing. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
24th Mar 2024 3:31pm |
PWC1c Member Since: 10 Oct 2015 Location: Hertfordshire Posts: 193 |
Thanks for the detailed reply really helpful .
I have a small Lazer light bar mounted in the middle of the Bumper and Lazer light Day time running lights they saved the day . |
24th Mar 2024 6:28pm |
