Home > Tdi > Snorkel and Alternative Airbox - 200tdi
bodstruck
I am looking at ways to install a better sealed air intake system on my 200tdi 110.
Current setup is a 'std' metal raised air intake on the drivers side using the original ducting leading to the standard airbox that has had the drain and joints sealed.
The ducting has been removed and reinstalled using decent sealant and it has been working quite well.
In preparation for an upcoming trip I took the airbox off to check for water ingress and there has been a fair bit. So much so that the lid of the airbox where the drain valve is has rusted through.
So a good opportunity to look at alternatives.
Southdown was my original plan but they don't seem to be available anymore.
I still have a Naka wing-top mounted snorkel from the puma - I could fit that and route pipework and a reducer to the standard airbox.
Some other solution?
I would also like to fit an airbox with less chance of leaking / letting in water, the standard one does seem to be a bot prone to it. The Alisport one looks nice but expensive. Any other suggestions?
Thanks
Post #1027950 13th Mar 2024 5:44pm
