Home > In Car Electronics > TD5 Dipped Beam Stopped Working - Whilst converting to LED |
ijefferyes Member Since: 11 Apr 2020 Location: Radstock Posts: 35 |
I am trying to convert my 2002 TD5 from standard headlights to LED Lynx Halo headlights.
Took the front apart last weekend and then this weekend tried to install the new lights. After only plugging in one of the LED headlights, I switched on the lights to check they were working. At this point, I didn't get any dipped beam light. So, I plugged the standard light back in but still didn't get any dipped beam and strangely neither front light works. Full beam comes on from both sides, but no dipped beam on either. Tried swapping both headlights to the LED lights. Still no dipped beams, but full beam works. So, what have I done? Checked fuses and all look good. Rest of the lights, side lights, indicators, fog light seem to be fine. Unfortunately, didn't think to check that the headlights worked today before making changes, but they worked last weekend. I can't see a dip/dim fuse under the wing, although there does seem to be a plug, which goes live when the slide lights come on. Click image to enlarge |
27th Jan 2024 9:36pm |
Thanks for the feedback.
Looking in the fuse box if I am reading the symbols correct, it suggests there is a fuse per side, both dipped and full i.e. four fuses. Will get a picture tomorrow. Again it would be weird if I had tripped the fuses for both sides, without having touched one of the sides. The wiring loom is also unmolested. I think as you suggest, time to check the switch and get the multi-meter out. The switch has gone before, but long time ago. Then it was more intermittent than this. Ian |
28th Jan 2024 12:28am |
All sorted. Didn't realise the TD5 could also have the relay behind the dash. Have bypassed this and it now works!
28th Jan 2024 3:56pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19658 |
Glad to hear you managed to get it sorted out.
Even though you have gone LED, which will extend the light switches life span greatly. Don’t discount the idea of fitting an additional lighting loom, as that can reduce the current through the switch even further down to under 500mA. Or 0.5A and lower. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
28th Jan 2024 9:10pm |
