Home > Wheels & Tyres > Bespoke replacement spare wheel cover |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 332 |
I had one from them last year made to fit a 255 85 16 tyre, very good it was too. It fitted perfectly.
14th Jan 2024 2:23pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1797 |
@markbrown. Was it semi ridged or soft vinyl ?
Ps keeper, you seem to have created two topics on the same thing, and asked the same question on a 3rd existing topic... you can just add to an existing topic or just create one new one and add to it. That way all will be in one place for you and others to find easily. |
14th Jan 2024 2:30pm |
Keeper Member Since: 14 Jan 2024 Location: Cambridgeshire Posts: 7 |
The Sign Maker can make semi-ridged or flat. They make floppy ones which are flat no ridges or ones with a more robust firmer front for a logo to successfully attach properly. Have a look, I just happened to come across it then went on their website. It's very comprehensive.
Thank you for advice on using this forum I've never used a forum before so just need to get the hang of it. |
14th Jan 2024 4:37pm |
The one I had was black floppy vynil, with black piping. It's fully elastic fit, a nice job. I suppose that it doesn't really serve any purpose, but I think that it adds to the retro (ish) vibe on my 110 and sort of looks finished. Mudflaps next!
14th Jan 2024 7:15pm |
Thanks MarkBrown, The sign maker and Aquarius are similar in that they can make a soft vinyl cover of any size, inc a 33 inch diameter size you need for a 255/85 R16, I’ve been looking for a semi ridged cover for my 33 inch diameter 255/85 R16 BFG MT setup but unfortunately both companies only go to 32inch diameter with a semi ridged cover.... the search continues
15th Jan 2024 3:17am |
