Home > Tdi > Grease nipple for water pump |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3219 |
Usually there is a drain hole, so that if the seal leaks, the bearing does not fail.
But from your picture in the gallery, looks like hole is on the side? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
9th Dec 2023 9:12pm |
LHolden Member Since: 11 Jul 2023 Location: Rabun COUNTY Posts: 4 |
Thanks for your quick reply. This hole is definitely beneath when it’s installed which makes it an odd place for a nipple fitting.
9th Dec 2023 9:39pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2557 |
That’s because it’s not one, it’s a drain hole as above. When water leaks out, you know the pump is failing.
9th Dec 2023 10:44pm |
10th Dec 2023 1:46am |
