Home > Wheels & Tyres > Winter tyre pressures |
nicolas0505 Member Since: 23 Dec 2020 Location: briançon Posts: 79 |
Good morning
Manufacturer tire pressure is set at a temperature of 20 degrees Celsius. tire pressure varies from 100 grams for 10 degrees, example tire inflated to 2 bar at 20 degrees if I go to a country with a temperature of 40 degrees I would have 2.2 bar and if I go to a country with a temperature of -40 degrees I would have more than 1.4 bars. the pressures are taken cold tire of course |
9th Dec 2023 12:28pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5429 |
I’m happy to run lower pressures in the winter. Gives a bigger footprint.
9th Dec 2023 12:36pm |
