Home > Faults & Fixes (L663) > Failed Signature DRL fix |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2280 |
Well, that's fabulous news because these light units are nearly £3,000 each and once out of warranty you are on your own.
23rd Nov 2023 7:30pm |
Moo Member Since: 01 Oct 2021 Location: Bath Posts: 1061 |
How much!
That’s just bonkers. Once the thieving parts scumbags realise the cost of these things then expect to see a rise in thefts Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
23rd Nov 2023 10:10pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3262 |
Yes, had both replaced under warranty on my Velar as they were cracking, it was a battle. £2.5k + VAT per corner. The rears cracked as well, though there was a technical bulletin for the rears 24MY 90 D250 HSE, Tasman Blue
23rd Nov 2023 10:48pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1337 |
The chip he is talking about has been available for quite some time now, you can get them from China for about £15, as usual it's not something he has discovered, he is just copying what other people do and then will charge a premium for it Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
24th Nov 2023 12:57am |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 647 |
£3000 each!…… how is that even possible? You could buy a half decent Ford Fiesta run around for that money or even an old style Defender that needed a little bit of work.
Land Rover really have alienated their old school supporters….☹️ Jim |
24th Nov 2023 5:47am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6489 |
Classic Defender headlights, £20+VAT each. Progress 1988 90 Td5 NAS soft top
2015 D90 XS SW |
24th Nov 2023 7:44am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3623 |
24th Nov 2023 10:19am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2557 |
The standard base spec lights are much cheaper luckily.
24th Nov 2023 7:59pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 808 |
I am getting old I suppose, but when I shop for a second hand car, I do research on what fancy stuff to avoid because when it breaks it's typically expensive to fix.
So when I am ready to buy my pretender I will be looking for the base spec. |
24th Nov 2023 8:03pm |
There's often ways around replacing these expensive parts, as above. lf it's a common failure there's likely to be an aftermarket alternative or a repair possible, as the vehicle gets older and aftermarket companies start looking at ways to make money from it.
6th Dec 2023 9:17am |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 125 |
That's what I did buying it from new and was pleased, much later, when I discovered how much the fancy ones cost to replace. Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
6th Dec 2023 11:08pm |
