Home > Faults & Fixes (L663) > low coolant warning light |
stu_007 Member Since: 23 Jan 2014 Location: Cardiff Posts: 99 |
Coolant tank all replaced and security update all done on the driveway by LR assistance… hope this solves the problem 🙏🏻 Current
2021 D110 HSE 2013 D90 XS Previous BP07 OZR D110 (1930 YBA) 2007 G4 Mongolian Recce Vehicle BP52GHZ D110 2003 & 2006 G4 Event Vehicle |
2nd Apr 2024 1:27pm |
NigelM Member Since: 20 Nov 2014 Location: South Posts: 114 |
Dealer replaced the sensor on mine 2 weeks and 800 miles ago. Not seen the light since. 2001 110 TD5 (sold)
1999 90 TD5 (sold) Various FFRR & RRS (sold) 110 D300 X-Dynamic HSE (current) |
2nd Apr 2024 2:09pm |
Just the sensor?? Current
2nd Apr 2024 2:11pm |
So they said, but I didn't watch them do it. 2001 110 TD5 (sold)
2nd Apr 2024 2:17pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 808 |
I had this issue on a V8 D4 and changing the sensor on the tank did not make a difference because the problem was with the float inside the tank sinking which the sensor uses to read the level. On a D4/D3 the tanks are available aftermarket, but first I had to waste some money on the sensors...
Obviously it could be a different system, but often the low tech stays the same. |
2nd Apr 2024 2:54pm |
Thanks… what I meant was if it’s under warranty a whole new reservoir and sensor would be better as it maybe the sensor moving in the bottle… Anyway glad it’s solved your issue👍🏻 Current 2021 D110 HSE 2013 D90 XS Previous BP07 OZR D110 (1930 YBA) 2007 G4 Mongolian Recce Vehicle BP52GHZ D110 2003 & 2006 G4 Event Vehicle |
2nd Apr 2024 3:14pm |
I had a look at old one and sensor could easily move around on old one and was fixed solid on new one🤷🏻♂️ Current 2021 D110 HSE 2013 D90 XS Previous BP07 OZR D110 (1930 YBA) 2007 G4 Mongolian Recce Vehicle BP52GHZ D110 2003 & 2006 G4 Event Vehicle |
2nd Apr 2024 3:16pm |
