Home > Wheels & Tyres > Twisted Sport / OEM Sawtooth / Blindo
The Fox
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
My 90SW is running on the original Boosts and 235/85/16 Conti CrossContacts, but the rims are now badly corroded and the tyres approaching the end of their days. 95% on road use, they've done well.
Torn between Twisted Sport, OEM Sawtooth & Blindo wheels. All in 16" and shod in 265/70/16 KO2 (or similar) AT tyres. They all seem around the same price point.
Like the look of them all, so looks not a factor - but I'd appreciate any long-term experiences with the above wheels and tyre size combo especially relating to corrosion/wear/offset/other issues.
Post #1012751 26th Oct 2023 5:06pm
ibexman
No brainier really Blindo as used on military WOLF
Post #1012760 26th Oct 2023 6:31pm
Ianh
Re: Twisted Sport / OEM Sawtooth / Blindo
Did you mean 265/75r16 , not 265/70r16 ? as it’s the former that you would normally fit as a 265 on a 16 inch rim
235/85/16 = diameter 31.7 inch, width 9.3 inch (standard size)
265/75/16 = diameter 31.6 inch, width 10.4 inch
285/75/16 = diameter 32.8 inch, width 11.2 inch
255/85/16 = diameter 33.1 inch width 10 inch
Post #1012772 26th Oct 2023 8:14pm
The Fox
I do mean 265/75/16, thank you.
Post #1012819 27th Oct 2023 9:35am
MercianRover
United Kingdom 1998 Defender 110 300 Tdi CSW Java Black
Blindo are heavy - this will have an impact on fuel economy if you do lots of urban driving.
They look good for the 'gram though Wink
Post #1012826 27th Oct 2023 10:03am
Simboii
Wales 2006 Defender 90 Td5 HT Keswick Green
Nice set of twisted in the forsale section Cool
Post #1013415 31st Oct 2023 8:08pm
90 Dreamer
Blindo’s but I may be a little biased……. Cool
Post #1013431 31st Oct 2023 9:39pm
LJMARSDEN
United Kingdom 2006 Defender 90 Td5 HT Java Black
looks nice, which springs are you runnning mate? Luke Marsden
06 V8 1UZFE Defender 90
Instagram: https://www.instagram.com/defender__v8/
Post #1013435 31st Oct 2023 10:41pm
90 Dreamer
Mine is on Alive comfort springs & billies…..
Post #1013583 1st Nov 2023 9:50pm
LJMARSDEN
Would that be their "road spec" as that is what I have on mine however I'm sure it doesn't look as low...
Perhaps its just the aftermarket arches that make it look that way. Luke Marsden
Post #1013605 2nd Nov 2023 8:24am
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
LJMARSDEN - if those are the Lucari XTR2's then they are lovely wheels. I did want to go for these but i do think that the bowler wheels have to look the nicest on a defender....
 Defender 130 HCPU TD5
Post #1013613 2nd Nov 2023 10:09am
