Home > Faults & Fixes (L663) > AIR SUSS pwusssssh noise
milesg7
Does anyone else seem to get a venting of the air suss noise inside sometimes, normally not long after setting off. Could be more sensitive as it is a P400e and I can hear everything and the interior is sparse. If not I will add it to the list of 'please have a look' when it goes to the dealer. I have only had it a week so all new to me...! thank q
Post #1011939 20th Oct 2023 7:02pm
LR Nuts
I have a 3yr old L663. Each time I open any door, I get a 'Star Trek' wooooosh from the air suspension.
I'll be interested to what the Main Dealer tells you.
Post #1011949 20th Oct 2023 7:46pm
aquascape
The noise as you pull away so the air suspension raising the car back upto driving height. I think this is normal
Post #1011951 20th Oct 2023 7:54pm
LR Nuts
No, mine does it when the car is parked and not moved at all ??
Each opening of the door Wooooooosh, shut, still parked. Next opening of the door .... same Wooooosh ??
Post #1011957 20th Oct 2023 8:47pm
milesg7
aquascape wrote:
The noise as you pull away so the air suspension raises the car back upto driving height. I think this is normal
That would make sense. Thank you
Post #1011965 20th Oct 2023 9:23pm
