Home > Puma (Tdci) > Puma Recall N706; Front axle case flange reinforcement brkts |
Disneysland Member Since: 25 Apr 2024 Location: Yorkshire Posts: 4 |
Photo of my front axle. Is this ok?
27th Apr 2024 6:02pm |
Picture didn’t upload first time due my incompetence 🙄
Click image to enlarge |
27th Apr 2024 6:05pm |
htb2 Member Since: 02 Nov 2018 Location: aberdeenshire Posts: 510 |
Friction weld, its OK.
27th Apr 2024 6:25pm |
Thank you. 👍🏼
27th Apr 2024 6:54pm |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 647 |
Hi all
Has anyone got a photo they can share of the ones that we should be concerned about? Jim |
28th Apr 2024 5:27am |
Thanks Dinnu
Jim |
28th Apr 2024 6:49am |
Sorry for my ignorance, I take it that a friction weld it the method used in the photo below that is circled in red? If your axle looks like this then your vehicle is not part of the N706 recall?
Click image to enlarge Jim |
28th Apr 2024 7:01am |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 909 |
That is correct.
The friction welded axles are fine and not subject to the recall, as it has been alluded to previously of JLR's inability to understand the mantra of "if it ain't broke don't fix it" Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
28th Apr 2024 8:30am |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 808 |
I am sure LR regrets the decision to move away from friction welding, but 100% sure this was cost driven based on what suppliers were offering on the market.
'Normal' arch welding is perfectly suitable for this application, but if you keep seeking the bottom of the barrel with cost being a main driver (like many businesses are ran nowadays), you will find quality issues with welds being poorly controlled and failures happening. Although I can see this being stressful for many, old perfectly fine complete axles are still plentiful and easy to overhaul with quality parts and then easily swapped out. As problems go you can get rid of this one if you are a bit of a hands on defender enthusiast. I still have a 1996 vintage front axle in bits in my shed in France (Paris) available. With some new parts it be totally fine. |
28th Apr 2024 1:56pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16941 |
I am reasonably sure that LR doesn't give the proverbial pig's burp about the matter. It may be a minor irritation but so far has been financially insignificant.
The switch from friction to MIG was supposedly made because the FW machine was life expired, and had the MIG been done correctly there would not have been an issue at all. As far as I know the axle cases were not and have never been bought-in, they have always been manufactured by JLR. |
28th Apr 2024 3:12pm |
trevorg Member Since: 28 May 2022 Location: Aisne Posts: 46 |
This is the weld on mine with the bracket fitted.
28th Apr 2024 10:10pm |
