Home > V8 > Help identifying v8 fan shroud to improve cooling?
v8bitsa
Hi there, I'm trying to identify the correct cooling shroud piece I need to find to improve the cooling of my v8 "Defender" a bit more.
I say "Defender" in quotes because it's actually a bit of a hybrid with a shortened RRC frame, with a newer defender body on top.
Now from the pics I'm guessing that when this conversion was done, the engine is actually a bit further back than usually expected, which I aim to improve with a extension to the rad shroud / fan cowl however it'd be much better if I could also fit what I am assuming is missing at the top of the shroud/cowl.
If anyone can identify a suitable part number I'd really appreciate it!
Post #1009702 2nd Oct 2023 9:53am
Linds Hanson
Looks like the standard Discovery/RRC 3.9/4.2 MA on cowling, similar part was used on the NAS and Aniversary 4.0L Defenders too ESR3226
Post #1009712 2nd Oct 2023 11:03am
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
Agree with Linds Hanson. Should look like this.
 JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #1009716 2nd Oct 2023 11:20am
v8bitsa
Brilliant, thanks both! BTW, does the fan look far back to you also?
Post #1009818 2nd Oct 2023 8:53pm
Linds Hanson
It does look slightly further back, the cowling only just clears the alternator when the engine is in the correct position. Is your gearbox/transfer box on the correct V8 mounting brackets?
Post #1009920 3rd Oct 2023 4:48pm
Jimbob292
United Kingdom 2012 Defender 110 Puma 2.2 DCPU Zambezi Silver
If you still suffer with hot running, try some water wetter depending on what you're running in terms of coolant, 50/50 water (distilled preferred) and water wetter will help.
The radiator does a lot of cooling for the engine coolant, oil and if an auto the transmission cooler.
Post #1034034 7th May 2024 8:45am
Romadog
To answer your question...
https://new.lrcat.com/#!/1228/12822/13206/1034/13271
As others have said its the same as Disco 1
The shroud is too but you have to make cutouts to suit the Defender V8 EFI radiator pipes as they are different to the D1.
Suggest you check your viscous fan too as mine failed without a sound.
Post #1034040 7th May 2024 10:18am
Jimbob292
100% check your fan, should lock up at first start, then the centrifcal forces, slowly open the clutch to free spin.
Also check the blade for any cracks, when they let go, they go!
I had a blade come of my D1 v8, safe to say it shock the car, still got me home, viscous fan was still good, but replaced it, checked the water pump at the same time and replaced that, because of the cavitation damage.
Also replaced the radiator with a high flow radiator from GM Radiators, honestly never looked back.
inside the pump was starting to erode the housing.
Post #1034042 7th May 2024 10:43am
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
Yeah I had this fun a few years ago.
Whistle
https://www.defender50th.co.uk/viewtopic.php?t=2103 Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #1034099 7th May 2024 6:21pm
I’d highly recommend the kit from Revtec… we were once sat on the A55 in a jam and it was 27degC outside…and that was after the climb..if it can handle that…. It also gets hammered around a track and gets used in scatter rally events.
Post #1034368 10th May 2024 7:12am
