Home > In Car Electronics (L663) > Rear Windows Activation 110 Hard Top |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 849 |
LR do 'funny things' with 5dr commercial vehicle to stop owners converting them.
I remember the Disco 2 commercial having studs welded into rear seatbelt mounting holes. In answer to your question, have you looked at wiring harness not being plugged into main body harness, beyond the B pillar. |
17th Sep 2023 9:34am |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2642 |
What year is your car? Do you have a list of parts as this is something, I want to do 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
18th Sep 2023 11:56am |
mattlidster Member Since: 17 Jan 2017 Location: UK Posts: 17 |
Mine is a 2022
Removed both rear door wiring looms completely. Parts used so far New wiring loom Drivers side rear door LR171801 New wiring loom Passenger side rear door LR171817 ( I think that's the right way round!) 2 X new switches LR059773 2 X new switch facias LR064090 New door Moulding round small window LR149591 New door Moulding round small window LR149592 New front door window switch with mirrors and memory seats LR130144 Changed Car Config File via IIDTool MultiCAN-634 MovingWindows Four Moving Windows EUCD-109 Power Windows, Front/Rear DCU Powered Front & Rear Windows Last edited by mattlidster on 23rd Sep 2023 6:53pm. Edited 1 time in total |
18th Sep 2023 7:34pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1337 |
Did you change
MultiCAN-634 MovingWindows Four Moving Windows If that's the only one you changed, what is EUCD-109 set at on your car? On mine which is a car not the hard top mine is set as EUCD-109 Power Windows, Front/Rear DCU Powered Front & Rear Windows Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
18th Sep 2023 10:12pm |
I hadn't changed MultiCAN-634 MovingWindows
Four Moving Windows Now the rear switches seem illuminated but the rear buttons in front drivers panel are not. I have a new genuine 4 switch panel coming soon so will wait and try that. I cant believe how many settings there are in the CCF! |
19th Sep 2023 5:10pm |
I wouldn't worry about them, they aren't all for the Defender, they cover all the newer Land Rovers and there are even some Jag one in there Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
19th Sep 2023 5:19pm |
Swapped the drivers door switchs over to one I bought on ebay for a Disco Sport and now have control of rear windows from drivers door!
20th Sep 2023 5:44pm |
So looking at the internet, if I use the parts as mentioned earlier in this thread these are the costs I found
1. New wiring loom Drivers side rear door LR171801 2. New wiring loom Passenger side rear door LR171817 ( I think that's the right way round!) 3. 2 X new switches LR059773 4. 2 X new switch facias LR064090 5. New door Moulding round small window LR149591 6. New door Moulding round small window LR149592 7. New front door window switch with mirrors and memory seats LR130144 Costs 1. £221 2. £209 3. £11 each. so £22 4. £30 each so £60 5. £61 6. £61 7. £55 For a grand total of. £689 and then the cost of the IID tool Which makes it an expensive upgrade to just get 2 windows to open. 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
29th Sep 2023 1:38pm |
Mine came in a bit less but its about that. If you just want the rear windows to open from front of car you could get away with just the 2 looms and a new front switch (I got a disco sport one for £15 from fleabay) as well as activation.
30th Sep 2023 7:47am |
Paladino Member Since: 07 Dec 2022 Location: Serbia Posts: 30 |
Could you add the the part no. or a photo of the switches you bought? Do the button to disable rear windows work? Also does the child lock button work? Thanks |
15th Oct 2023 10:03pm |
Hi I will take a picture of part number next time I have it apart.
You can buy a new one which is this one: https://britcar.com/product.php/656309/5497/cover___door_switch and yes the rear child lock for the windows does work. |
16th Oct 2023 7:34am |
craigblues Member Since: 02 Aug 2015 Location: Worcestershire Posts: 11 |
I might being stupid here. Presume you didn’t try to activate the windows for global setting before changing all the looms? Someone mentioned to me the looms are already in there for it all to work, just no switches. I’m happy to be corrected though.
15th Nov 2023 10:00am |
My one def did not have any spare connectors or wires in there. The old loom I took out has a different part number to the loom I fitted. It wouldn't surprise me if they occasionally use what they have on the shelf at the time so is def worth looking as you may get lucky!
15th Nov 2023 10:31am |
Fair enough. Do you have any photos?
Was there anything plugged to the window motor though in rear? |
15th Nov 2023 10:41am |
