Home > In Car Electronics > Defender TD5 Cruise Control Install |
This is uselesss without photos mate... Useless...!
29th Aug 2023 8:01pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2082 |
Better?
Click image to enlarge Instagram @defender_ventures Empire Tuning - Agent |
29th Aug 2023 8:30pm |
Ahhhh that kit. Yes that is better. I kind of wish I had gone that route rather than DIY'ing it for myself. Very neat with the Disco switches.
Curious about the tacho wiring too, that is a neat extra to have in the loom. |
29th Aug 2023 8:39pm |
Jabberwocky Member Since: 27 Oct 2021 Location: Luxembourg Posts: 197 |
I wanted to do the same however I have a 10p engine with an nnn ECU which according to empire is a long way off in their plans🤷♂️
30th Aug 2023 7:33pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6489 |
If it's an NNN ecu it's got cruise. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
30th Aug 2023 9:26pm |
Yeah it should work! Instagram @defender_ventures
30th Aug 2023 9:33pm |
I asked empire if it would work and they said no.
31st Aug 2023 1:38am |
That is what I thought too. As long as you have an NNN ECU News to me. |
31st Aug 2023 8:45am |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1336 |
I have cc on mine, self installed. all need to remember if they have change transfer box to a different ratio you will need a speedo healer for it to work
31st Aug 2023 6:04pm |
Or ratios can be changed within the ecu software. No need for a healer. Instagram @defender_ventures
31st Aug 2023 7:04pm |
i didn't know that, as mine was a DIY kit made up from a thread i found, i had to use a speedo healer
1st Sep 2023 10:54am |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 541 |
I fitted Cruise Control about 10 years ago and 'upgraded' to the disco steering wheel switch about 2 years ago and it does look like it was meant to be there which I like.
I have a Roamerdrive so run the speed signal to the ECU through a 5pin relay so when the overdrive is engaged the speed signal is corrected by the Speedo healer, works a treat! Cheers Will 2005 90 XS 1954 86'' Series 1 tilt |
1st Sep 2023 1:03pm |
Sicastle71 Member Since: 21 Aug 2019 Location: West Lancs Posts: 126 |
Click image to enlarge Is this the correct speed healer. Do I just connect all the wires and program it. I have the 1.2 transfer box and 265 tyres fitted thanks |
22nd Sep 2023 10:56am |
Do you have a problem with engaging the cruise control then? Curious as I never did with the 1:1.2 transfer box in Miffy. I even have a speedo healer in the spares box that I took out because it wasn't needed in the end. Weird eh?!
But yes that looks like the right speedo healer. It connects in-between the speedo sensor and loom. I managed to route it through from the ECU compartment to the speedo gear through a grommet. Speedo healer was double sided next to the ECU. |
22nd Sep 2023 12:40pm |
