Home > Tdi > TDI 200 Year 1991 Oil Cooler Pipe
cykoh85
Malaysia 1990 Defender 110 200 Tdi SW Santorini Black
Hello everyone,
I need some help or opinions again.
When I changed my engine oil on June 2023, my intention was to also replace the oil filter housing gasket. However, I wasn't able to get it done at the time. Instead, I opened the waxstat adaptor and changed the O-ring, among other things.
After screwing back the oil cooler pipe (as shown in the picture), I noticed leaks starting to appear. Fortunately, I recently noticed the leaks becoming very obvious when the engine is running, and I estimate that about 800ml to 1L of engine oil has been lost.
As a response, I unscrewed the oil cooler pipe and applied white tape. This has improved the situation compared to before, but there is still a very minor leak, and I'm uncertain about how long this temporary fix will hold.
Do any of you have an idea about this? Should I consider changing to a new oil cooler pipe? Or is it possible to unscrew it and re-fit it properly again?
I think overtighten that time and caused the leaks Crying or Very sad
Thank you so much for your assistance!
Post #1004497 17th Aug 2023 3:47pm
Dinnu
I think I have a spare set of oil cooler pipes, will have to check how the seal is in the engine side. I am very sure its a taper seal in the radiator side. But memory is a bit hazy on how the sealing is on the engine side. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1004499 17th Aug 2023 4:24pm
cykoh85
Oh I see, Do you still intend to use it? It also has a taper seal on the engine side, but I believe it doesn't come with an O-ring (as earlier models don't have O-ring, correct?).
Post #1004502 17th Aug 2023 4:38pm
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
Correct. Very late 200 tdi had o rings but most are taper.
Post #1004520 17th Aug 2023 6:59pm
NickMc
Have you got the pipe support clip fitted? I would try some loctite thread sealer like 561 or 545 instead of ptfe tape, check locally though as what suits.
Post #1004532 17th Aug 2023 7:54pm
cykoh85
Mo
Yes, I think mine don't have the O-ring.
Post #1004557 18th Aug 2023 7:36am
cykoh85
No, so must have the pipe support clip? I think have to change a new pipe for better solution.
and thanks for your recommendation - loctite thread sealer, able to buy it here.
thank you.
Post #1004558 18th Aug 2023 7:37am
cykoh85
Dear all,
Update:
I noticed there is a leak even after I opened it and refitted it using PTFE tape. It appears that I really need to replace the oil cooler pipe for a better solution.
One more notice:
Does anyone know what this thing is (circled in red)? I also noticed some leaks at the bottom (circled in blue). Is there any gasket there? Please refer to the attached picture.
thank you.
Post #1006256 2nd Sep 2023 2:01pm
Dinnu
That is the brake vacuum pump. Yes, there is normally a gasket underneath it. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1006260 2nd Sep 2023 3:39pm
cykoh85
Alright, if I open it, will any fluids like brake fluid come out? Because I've noticed that the leak underneath is engine oil.
Thank you Dinnu Very Happy
Post #1006302 3rd Sep 2023 4:45am
Dinnu
No, no brake fluid. Just undo the 3 hex head bolts, and lift up. If now remember correctly there may be 2 gaskets, as the bracket for the throttle linkage is sandwiched between the vacuum pump and the engine block. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1006303 3rd Sep 2023 4:52am
cykoh85
Ok Dinnu.
As picture below, right?
Can I DIY the engine block gasket using a paper gasket?
Appreciated your helps! Smile
Post #1006304 3rd Sep 2023 5:47am
Dinnu
Yes and yes. I like to use fibre type of gasket when I need a diy approach. For this application, thickness is not so critical, but do not go too thick as would ‘warp’ the vacuum pump.
For extra measure, I do sometimes smear a small amount of RTV on both sides of the gasket. It also helps to locate the gasket, especially in this case as is a bit fiddly to align the bottom gasket, the throttle bracket, the top gasket and finally the vacuum pump, which shaft need to be in the correct position for the drive to engage all at the same time. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1006305 3rd Sep 2023 6:05am
cykoh85
Thank you, Dinnu. The information you provided is very knowledgeable. Well done. Bow down Very Happy
Post #1006340 3rd Sep 2023 2:22pm
