Home > V8 > Won't start..... |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 811 |
Is there definitely fuel delivery? Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
16th Aug 2023 5:57pm |
Ranger 6 Member Since: 17 Jan 2019 Location: Yorkshireman trapped in a Surrey postcode Posts: 187 |
yes - it's a spark issue not a fuel one 90 V8 CSW - 1988
16th Aug 2023 7:59pm |
Tried a new rotor arm? Charlie
16th Aug 2023 8:03pm |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 |
Wondering if your car is old enough to have an Alarm Spider in the dash board.
I had a Discovery 1 V8 1996 and they had known issues with it. It immobilizes the engine but it will still turn over. There is available on a ebay as bypass wiring fix which is plug and play. Good luck Don Cheers Don. |
17th Aug 2023 12:31pm |
Thanks all
Charlie - Yes Don - no, it's too old to have anything like that I'm purchasing a new Hall effect sensor for the dizzy and a new king lead - it's had an ignition amp and coil so far (as well as some wiring and checks with spare parts) 90 V8 CSW - 1988 |
21st Aug 2023 4:07pm |
Good luck,
Don Cheers Don. |
21st Aug 2023 6:05pm |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 251 |
Just curious to hear if you got this fixed and what the problem was?
15th Sep 2023 9:20am |
Sorry - no, still not running
Made the decision to find someone to do much more to it. I have another engine to go in and need some bulkhead work done at the same time. I'd like somewhere local to me that can take it, fix it and bring it back in a better state. Suggestions have been Safari Engineering in Eversley as the local places have either closed or don't do welding. 90 V8 CSW - 1988 |
18th Sep 2023 5:19pm |
Thanks for coming back - I hope whatever is done sorts out the issue for you.
18th Sep 2023 5:45pm |
Cheers - in the middle of rally season at the moment so the 90 is on the back burner
3 Shires and Rally Yorkshire over previous weeks and the Mull Rally next week followed by Bovington 90 V8 CSW - 1988 |
3rd Oct 2023 1:05pm |
Final update on this one.
It's being collected next week and I don't expect it back for a while. The bulkhead is going to be done as well as the engine build and a whole host of new bits to make it all work. Oh my aching wallet!! 90 V8 CSW - 1988 |
9th Nov 2023 6:24pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10546 |
It will be well worth it when you get it back again 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
9th Nov 2023 9:30pm |
