Home > Tdi > TDI 200 Lift Pump Area |
Do you mean the lift pump gasket? Or is it something else?
https://www.lrworkshop.com/diagrams/land-r...pump_53151 |
25th Jul 2023 11:04am |
cykoh85 Member Since: 25 Apr 2022 Location: Selangor Posts: 106 |
Hi Sir
Nope, I mean something else. Did you notice before the lift pump go in, there was a part (square shape) attached to the engine block? Click image to enlarge |
25th Jul 2023 11:46am |
Ah yes I see now. You are looking for HRC1873. It is bolted into place so just needs to be removed, cleaned and replaced either with a paper gasket of some instant gasket.
25th Jul 2023 11:52am |
Oh, I just google with the part number provided by you, the name is lift pump mounting plate,
thank you so much |
25th Jul 2023 12:34pm |
You are welcome. Good luck
25th Jul 2023 12:35pm |
