Home > Faults & Fixes (L663) > Park Brake Fault |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1337 |
Here are your photos
Click image to enlarge Click image to enlarge I would guess that the car has detected that the brake switch wasn't attached and has stored a fault in the system. If you don't have a suitable code reader you will have to visit your dealer or an independant garage that has a Pathfinder system to clear the fault. Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
23rd Jul 2023 9:59am |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 131 |
hi, it happened to me too
I solved it by disconnecting the battery negative connector for 5 minutes. worth a try. Cheers Marco |
23rd Jul 2023 10:25am |
