Home > Maintenance & Modifications > Feedback wanted on SP4x4's series door conversion a 110 CSW? |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2062 |
Looking very good
4th Apr 2024 6:55am |
Bowbearer Member Since: 12 Aug 2022 Location: Norfolk Posts: 133 |
Any tips fitting the doors or was it straight forward
I’m doing mine on the drive so waiting for good weather Yours is looking good, suits the doors, good colour choice. |
4th Apr 2024 7:27am |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
About as straight forward as it gets once you've removed the old door. And a much easier job for a single pair of hands compared to the push button doors since you can just fit the bottom part first. Keep the hinges bolted tight to the bulkhead, only loosen after fitting the door if you need to adjust things.
4th Apr 2024 11:37pm |
Just lined my doors with flashing tape 3mm and sound proofing.
Made a big difference sounds less tinny and more solid. |
10th Apr 2024 6:33pm |
