Home > Tdi > Downpipe resting on crossmember |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6046 |
I had a galvanised on advertised on here for free as well a while back
No-one wanted it and I chucked it in the end. Typical. |
30th Jul 2023 8:01am |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 790 |
That sounds like the ideal solution, I shall look into that, thanks. Diesel_Jim - shame, and I have the same thing myself. Sometimes you can't even give stuff away and they end up taking up too much space. My current challenge, whichever way I go, is getting the old crossmember off. It is stuck solid. I know I need to spread the chassis legs but I can't get the high lift under there, the bottle jack doesn't work on its side and the only scissor jack I have is from my van and it is too big to get into a useful position. |
30th Jul 2023 9:42am |
