Home > Faults & Fixes (L663) > Coolant leak and dealer repair time |
Telemarkskier Member Since: 20 Jul 2020 Location: Wiltshire Posts: 116 |
Have you another dealership nearby that could do it quicker? 2020 Defender 110 SE 240D: Fuji White.
2011 Freelander 2 SD4 HSE 2007 Freelander2 HSE (man) |
21st May 2023 3:56pm |
ben2012 Member Since: 10 Oct 2011 Location: Uk Posts: 63 |
They are as bad if not worse 🙄 time scale wise
21st May 2023 4:12pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2557 |
2-4 weeks is pretty quick these days sadly.
21st May 2023 6:50pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2281 |
Why not repair it yourself, remove the "one use" crimp connector and put a worm drive or Jubilee clip on instead.
Time taken, ten minutes if that. Make sure it's a genuine "Jubilee" branded because the aftermarket ones often have a bulge on the inside where the worm drive is located. I am surprised LR Assist couldn't do that, maybe it's a warranty issue that you have to fit the correct "one use" crimp type. |
23rd May 2023 4:03pm |
