Home > Faults & Fixes (L663) > Defender Center Channel speaker |
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 252 |
The 11 speaker system does not have a centre speaker, so it’s odd that there is one fitted, but as you say it doesn’t work. See info below
https://www.lrdefender.org/speakers-818.html 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar |
30th Apr 2023 8:50pm |
Defhead Member Since: 28 Mar 2022 Location: Arizona Posts: 5 |
Click image to enlarge Thanks whiterdesign for your reply and the link is so helpful You can see the image that there is a speaker and i also opened the trim and found it already wired. By any chance can i get it to work or should contact the dealership about? |
1st May 2023 6:06am |
mf7480 Member Since: 14 Jun 2021 Location: Gloucestershire Posts: 86 |
What engine do you have? Is it a speaker for false engine noise?
1st May 2023 6:30am |
Hi mf7480
i have the 110 HSE P400 I6 |
1st May 2023 11:10am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2343 |
Well, that another feature l don't have to worry about on my base spec Commercial
All l have under that cover is a hole. TBH l am surprised the audio system sounds so good with only two door speakers and two tweeters. When you are moaning about your "lousy" ten or thirteen speaker/sub setup, think of me with four speakers and no sub. |
4th May 2023 6:30pm |
Drink some tea it might help
5th May 2023 11:57am |
