Home > General & Technical (L663) > New Defender security |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2280 |
lt's a good idea.
Spare wheel theft is definitely an issue, unless like me you have the white steel wheels lt seems you can't give them away. |
21st Apr 2023 12:38pm |
Mudlark Member Since: 14 Oct 2022 Location: North West Posts: 24 |
Has anyone had experience of a Ghost Immobiliser fitted to a new Defender as I am about to take delivery and a little concerned about theft but heartening to read that they are not that easy to steal.
Any comments gratefully received. |
29th May 2023 1:25pm |
DrRob Member Since: 29 Mar 2017 Location: Hampshire Posts: 78 |
Mudlark - did you have Ghost fitted in the end? New 90 on order for delivery in May 2024. D300 X-Dynamic HSE in Eiger
2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory interior and clear glass = "Rory" Will be up for sale in Spring 2024 1974 Series 3 Lightweight = "Millie" -------------------------------------------------- Series 2A V8 Lightweight - gone 1952 80" - gone 1949 80" - still in family since 1975 |
28th Mar 2024 8:55pm |
johnlad Member Since: 18 Dec 2023 Location: Blackpool Posts: 35 |
I’ve a ghost on my d300, once you get used to the starting sequence it’s great, but initially you’d forget, the car would start but as soon as you got into gear it would shut down. Then wait a few seconds and go with correct starting sequence and all good.
It becomes second nature. |
29th Mar 2024 8:29am |
Thanks. Does your remote start on In control app still work with the ghost fitted? I’ve heard you need to mention it on install New 90 on order for delivery in May 2024. D300 X-Dynamic HSE in Eiger
29th Mar 2024 8:34am |
Hi DrRob, Yes I did have it fitted and so far all good. It took a little time to get the PIN sequence off by heart but it's a great security blanket as it would be nigh on impossible for anyone else to guess the sequence even if they knew it was installed. It has a service mode when it needs to go to the dealership but this also has a background setting so even if it was stolen from the dealership it couldn't be taken too far. |
29th Mar 2024 10:55am |
Telemarkskier Member Since: 20 Jul 2020 Location: Wiltshire Posts: 116 |
apart from the coolant header tank replacement work, my 2020 Defender had recalls for :- N815 NFSM Wired Updates and N888- Security enhancement (Phase 4)
Click image to enlarge 2020 Defender 110 SE 240D: Fuji White. 2011 Freelander 2 SD4 HSE 2007 Freelander2 HSE (man) |
29th Mar 2024 12:05pm |
I’ve never used the remote start so cannot comment on that, but I can’t ever see a reason for me to start the car without being there. Also all remote features are off whilst in Guardian mode. |
29th Mar 2024 2:38pm |
Soup Dragon Member Since: 22 Sep 2023 Location: Cheshire Posts: 75 |
Telemarkskier - why have you been charged for recall work, this should be FOC even if you are out of warranty?
29th Mar 2024 3:04pm |
Its just their internal audit trail. Bill goes to Land Rover warranty claims not my wallet! That empties quick enough when filling up with diesel. 2020 Defender 110 SE 240D: Fuji White.
29th Mar 2024 4:06pm |
martinf Member Since: 30 Nov 2020 Location: Sussex Posts: 96 |
My dealer has asked me to book my MY2022 P300 110 in for security update N693.
I am unclear why others have a different update number. Is it because mine is petrol rather than diesel I wonder? |
29th Mar 2024 5:51pm |
