Home > In Car Electronics (L663) > LR dascam |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1342 |
As far as I can remember, you can use an app like VLC to open the saved clip, then go to video>video track and you will be able to view tracks one and two, the rear camera is on the second track Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
19th Mar 2023 1:02am |
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 250 |
Hairy Dan thanks for your suggestion but can't seem to get it to work.the only reference to a track is on the audio side of it and that only shows track 1 Its probably me I haven't played with VLC for a long time 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
19th Mar 2023 6:39pm |
No sooner had I sent the last message , I got it to work,basically how you said. Don’t seem to be able to do it using the IOS app but works on my Mac. Thanks for that 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
19th Mar 2023 6:51pm |
martinf Member Since: 30 Nov 2020 Location: Sussex Posts: 97 |
When I open a Downloaded recording in the LR app there are two dots below the video. And there are the words "Front camera" and to the right "Rear camera". By swiping left from the front camera you get access to the video from the rear camera. So it is all there on the iPhone.
Downloading a tedious business which I achieved by connecting my iPhone to my Mac. |
19th Mar 2023 7:02pm |
Martin,you are correct, but that's in the LR app .you can't do anything with that video if you wanted to send that video to someone as evidence you cant. the app does create a file called Dashcam where the video is saved but thats where the problem starts .if you play the video from that file you only see the front dash cam recording. Thats the question i was asking. thanks to Hairy Dan he suggested using VLC which enables you to see both of the tracks.the only problem i have still got is how to save these as 2 separate tracks 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
19th Mar 2023 7:12pm |
Sorry, I should have mentioned I'm using vlc on my mac, I can't do it on the phone, at my age the screen is too small I will say that the Land Rover Dashcam is probably one of the worst I've seen with regard to viewing the feed from the rear camera on anything other than my mac The only way I can see how to 'split' the file is to play track 2 and screen record the window using Quicktime, probably not the best way to do it but that is the only way I know how to at the moment and it is a really crap way of doing it Cheers Ian
19th Mar 2023 7:43pm |
