Home > Faults & Fixes (L663) > Brake Judder |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1337 |
Just to update this further, I went into a different dealership today and just said that I had a brake judder and could they have a look at it, one of the service guys went out with me and even before we got to the end of the road he confirmed it has brake judder! It's probably just the fronts but they will look at the rears when it goes in. It's booked in for November 9th and they have said if it is warped discs they will be replaced under warranty. So hopefully it will be sorted in a couple of weeks. Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
27th Oct 2022 2:29pm |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
Great result.
My wife has started juddering fairly significantly, although with 20k on the clock I should think I'm in for a large bill ! https://www.instagram.com/hustynminepark/ |
28th Oct 2022 8:48am |
Shouldn't you take her to a doctor...? Darren
28th Oct 2022 10:00am |
Ha ha, you’re absolutely right !
I should have said ‘my wife’s defender’ , although she is a little juddery nowadays to https://www.instagram.com/hustynminepark/ |
28th Oct 2022 10:23am |
Well I have the car back and it's fixed and all covered under warranty. They said the discs were warped and that there is a 0.1 allowance, the lady on reception didn't know what the 0.1 measurement was but I'm going to assume either millimetres, centimetres or metres The n/s/f was 0.3 out and the o/s/f was 0.4 out, they checked the rear discs and they were fine. They also carried out a recall while it was in and I was told that they replaced the power steering idler and the belt Cheers Ian
15th Nov 2022 12:54am |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 960 |
Great result, well done for being tenacious and not accepting poor service Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
15th Nov 2022 9:10pm |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 125 |
Excellent result, Dan. It's a pity the dealer response seems to be "postcode dependant" Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
16th Nov 2022 10:49pm |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1542 |
more like they charge you for the work, then claim warranty on it from jlr....
not many good dealers in the jlr network around us that's for sure. |
16th Nov 2022 10:57pm |
Cheers guys, it was a bit of a relief to get it covered by the warranty
Did you use original parts Retroanaconda? Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
17th Nov 2022 1:12am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2557 |
Yes OEM, same spec as what came off.
17th Nov 2022 7:55am |
Cheers Ian
17th Nov 2022 8:03pm |
Bumpymike Member Since: 18 Nov 2015 Location: cheshire Posts: 70 |
2022 Defender XS 110 - 12 month old and 3,000 miles brake judder due corrosion on inner front discs… warranty declined and quoted £940 for new discs & pads.
On 20 inch wheels so new discs are £220 each. Discs are manufactured by Brembo under copyright due to disc being bonded to alloy hub that goes on wheel studs. The vehicle lives in a urban area and never seen mud. Discs get changed tomorrow so can have a look at inner face were corrosion had taken place. So I have dilemma ahead …. Next set of discs will rust in next 12 months and need changing so the vehicle is no good for my use…. My Defender 90 Tdi had new discs in 2009 & given no problems over 30,000 miles |
4th Sep 2023 7:08pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2280 |
This is a concern.
I changed the discs and pads on my old Defender and they lasted 90,000 miles and were still okay. So far my new D250 has done 7,000 miles with no issues. £900 for two discs and pads replacement is excessive. If it happens to mine and it's not under warranty l'll take the discs off and get them skimmed. My local machine shop will do this for £60. They say once discs have warped and been skimmed they won't warp again. |
4th Sep 2023 9:30pm |
Yes, I agree with you - vehicle is at a LR independent workshop with full machine shop.
Am just disappointed that JLR spout luxury & sustainability but can not put a set of discs on a vehicle that can do 30k miles at least ! |
4th Sep 2023 9:38pm |
