Home > Puma (Tdci) > SSM40308 - Just to be aware
Eduardo
Just appeared in the GTR:
Models
LD - Defender
Title Mulitiple Starter Motor Failure
Last Modified 21-JAN-2009 17:43
Category Electrical
Symptom 203000 Basic Electrical
Content
Issue:
Repeat failures on Defender starter motors.
Cause:
The ignition switch can jam causing starter motor failure due to over running.
Action:
If the starter motor has failed check operation of ignition switch;
a) Is the switch jammed through any of its positions?
b) Does the switch fully return to position 2 once cranked and the inhibit operates, not allowing re-crank from position 2?
c) Does the starter motor continue to engage once cranked and key released?
If the answer to any of the above is YES please change ignition barrel as well as starter motor as potentially the starter motor will fail again.
Vehicles post vin. 775971 have been modified and should not demonstate this concern.
Cheers Eduardo
Post #6610 26th Jan 2009 9:55pm
Caterham
funny that - not quite the same but on 2 occassions I've been unable to move the ignition to stage 1 from 0 (if thats the correct positions - ie from off to 1st position) - and no its not because of the steering lock.
The first time it happened I was just about to abanded the vehicle and then it worked Question
No issues with the starter though.
Post #6612 26th Jan 2009 10:12pm
mse
Steering lock - ive never had one of those on a defender. Mike
Post #6613 26th Jan 2009 10:16pm
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
My TD5 had a steering lock, and it caught me out a time or two. Wasn't the easiest to disengage.
Post #6619 27th Jan 2009 8:14am
mse
Ive got to check for this now, ive not ever come across one and always thought it was odd...i assume its no more turns than any other car>? Mike
Post #6633 27th Jan 2009 3:21pm
dullbird
Australia 2007 Defender 110 Puma 2.4 SW Tonga Green
mine goes on really easy on the disco just got to bump the steering wheel, not so sensitive on the defender.
MSE: before you put the key in give your steering wheel a wobble and you will hear a short click then you wont be able to move it at all.....you then put the key in the ignition and you might find you have to give the steering wheel a jiggle as your turning the key to get the lock off YOU KNOW REHAB IS FOR QUITTERS!!!!
Post #11867 12th Jun 2009 9:40am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Mine's fine and I'm 14,000 short of the VIN cut off Sad
Turns on and off very positively.
Oh well, one more to file away. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #11873 12th Jun 2009 10:43am
mse
It locks i found out - but with amazing movement to get it to do it! Mike
Post #11893 12th Jun 2009 7:12pm
