![]() | Home > Puma (Tdci) > Heated rear screen.. |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2056 ![]() ![]() |
High level brake light rubs through the glass electrical element. I had to run a wire up the side of the glass(tucked behind the rubber) to the brake light to get it to work again. My 3 elements for the heated rear screen are not working either. I have posted about this before so look up my posts and you will probably find more details.
faulty batch of windows don't know if LR will still cover it under warranty 2.4 90 XS
![]() I do same diggings on the rubber to avoid the contacts from rubber the heater elements and and now, after 2 years is still OK ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
So again it is a case of "they all do that" and not a bad batch as i recall. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Not 100% sure but I think the bad batch I read about may have been front screens. Steve.
no it was the rears,we had ours replaced under warranty as did quite a few others 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
Ah right ![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
would there not be a TSB if this was a knows issue ? Maybe someone with topix could check.
Pom |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Both mine were replaced under warranty. The rear for a known issue with the brake light rubbing the element BM52
insulation tape over the wires stops it re occuring
![]() 1968 1/32 scale Britains 109 Pick up. |
Lastest rear glass are differents, new routing outside rubber zone for the heating elements ...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
