Home > V8 > Exhausts |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 723 |
There are off the shelf items, for example the Double-S system which I bought for mine:
https://stainlesssteelexhausts.co.uk/land-...st-system/ The manifolds were touching the chassis rails so I ended up ditching them, but hey it was off the shelf 2005 Td5 90 XS 1989 V8 110 CSW |
12th May 2022 9:20am |
MercianRover Member Since: 07 Apr 2022 Location: Culworth Posts: 124 |
I built the system on my 100" Bowler using parts from Jetex, it's a bit like lego.
I used 2.0" for the y-piece to 2.5" thereafter - might be worth a look if you can weld. |
12th May 2022 9:27am |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 811 |
I had seen that system, but comments about the headers touching the rails have put me off. How does it sound though? Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
12th May 2022 10:29am |
Sadly I can’t weld! Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
12th May 2022 10:30am |
I'll tell if I ever get it started... I ended up using cast manifolds and welding a connection piece on. Like you I couldn't weld before this project either, now I'm addicted to welding (although many would say I still can't weld) 2005 Td5 90 XS 1989 V8 110 CSW |
12th May 2022 3:32pm |
Ah, righto
It’s something I’d love to learn, but don’t have a workshop to support the kit needed. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
12th May 2022 3:38pm |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 445 |
Just fit RRC/Disco one 3.9 manifolds, RRC/D1 twin front pipes and y section, then bolt straight up to the standard TD5 110 silencer and tail pipe. You will need the TD5 exhaust mounts and bolt on chassis brackets too. This is much better than the SS tiny system and gives a nice deep note
12th May 2022 6:09pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16941 |
If it is of any interest I have a pair of genuine V8 manifolds taken from a V8 90 surplus to requirements and I'd be glad to sell them. They're in good condition and fully usable, and also include the heat shield thingy in the photo.
I rather suspect that you have an identical pair already fitted to your motor though. |
12th May 2022 7:25pm |
Thanks for the offer, blackwolf, but they look like what my 110 has fitted at present. Charlie
12th May 2022 8:04pm |
I think I’ve decided I’ll go for 3.9 manifolds with a custom system from there back.
So, does anyone have any 3.9 manifolds for sale? Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
13th May 2022 12:14pm |
Ranger 6 Member Since: 17 Jan 2019 Location: Yorkshireman trapped in a Surrey postcode Posts: 187 |
I've got some 3.9 manifolds fitted to mine (sorry, can't help with any more ) with this solution for the exhaust:
As mentioned, it's a decent sound, nice and deep without being tinny, and a sensible noise level. I did find that a set of BBW needles also lifts the drivability and throttle response. 90 V8 CSW - 1988 |
24th May 2022 4:44pm |
Don't know if this will help - here's a sound clip of the TD5 exhaust on a 90 with 3.9 manifolds
https://youtube.com/shorts/PCcFFEJwHcI?feature=share 90 V8 CSW - 1988 |
24th May 2022 6:21pm |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 689 |
I used a guy at the garage in Oare near Marlborough to make me a stainless system for my series 1, which runs a 2.5l petrol with ACR SU carb and branch manifold.
Not cheap but he made a good job. |
25th May 2022 2:02pm |
I’ve got a set of 3.9 manifolds to work with now, but I’m going to have a bespoke system made at a place near Stroud. Charlie
25th May 2022 5:07pm |
