Home > P400e Area (L663) > Load space liner |
nick19 Member Since: 10 Jul 2021 Location: East Yorkshire Posts: 19 |
Has anyone with a P400e managed to find a load space liner which is actually made for the P400e with its raised boot floor?
I’ve tried at least half a dozen suppliers and none currently have a template for the P400e. My P400e is due to arrive in June and am keen to find a solution before it arrives. |
28th Apr 2022 2:21pm |
Thanks DAP2022 I'll take a look at that.
4th May 2022 11:59am |
Scottie79 Member Since: 14 Jul 2022 Location: Scotland Posts: 7 |
anyone else found a liner that they could recommend ? ideally just a floor one rather than up the sides as well
13th Oct 2022 9:42pm |
Nick-St Member Since: 23 Apr 2013 Location: Surrey Posts: 267 |
Think it’s pretty poor that LR don’t make one that fits!
1st Mar 2023 7:56pm |
JARowley Member Since: 28 Dec 2022 Location: Nottingham Posts: 88 |
anyone ever find a solution?
6th Jun 2023 1:46pm |
I have to say that the raised floor is the most annoying thing about the P400e! It's not the fact its raised, but the slopes round the edges - if I put things near the door, they want to fall out of the boot because of the slope!
16th Jul 2023 9:20am |
carltb Member Since: 06 Oct 2023 Location: Sweden Posts: 32 |
I´ve ordered a custom bootliner fom Witamats. Quite skeptical but will let you know how it is when I receive it at Easter. 2024 Defender 110 p400e HSE
2015 Defender 110 Double cab 2004 Defender 90 Td5 |
18th Mar 2024 10:35am |
Coxy651 Member Since: 19 Mar 2024 Location: England Posts: 1 |
Yep I am also in the process of looking but so far no luck
Will let you know if I find anything 2024 Defender 110 P400e SE - Pangea Green |
19th Mar 2024 10:59pm |
Metisse Member Since: 03 Jun 2022 Location: Wiltshire Posts: 1 |
I decided to get the Land Rover version VPLES0566 that is not recommended for the PHEV. It is just a tad too wide and so has a very slight ruck tot he sides in the area around the hump in the boot but that doesn't matter as it is unsed space anyway. If you want you could trim a very small sliver off the edge and it should sit down properly. Across the top of the hump and front to back it sits flat and is perfect for our muddy dog!
See my gallery for photos. I got mine from woodacre4x4 on eBay at a very good price, just had to wait a bit as they were on back order. Hope that helps. 2022 Defender 110 HSE P400e Tasman Blue |
23rd Mar 2024 11:29am |
Thank you for the photos. That looked much better than expected. I will definitely go for that one if the one I ordered is not satisfactory. 2024 Defender 110 p400e HSE
24th Mar 2024 6:02pm |
milesg7 Member Since: 13 Sep 2023 Location: Cheltenham Posts: 61 |
I have one I bought from Predator 4x4 which has Defender on it, heavy rubber and my solution is to keep an umbrella under each raised side, which I would keep in the car anyhow, and the mat sits above them. Works well for me, I carry bikes, cases, tool kits etc in my boot with no issues.
25th Mar 2024 3:13pm |
So the "custom" mat I got from Witamats pretty much sucks. So I will go with the same as Metisse recommended above. 2024 Defender 110 p400e HSE
3rd Apr 2024 8:51am |
RobbyDefender Member Since: 04 Feb 2024 Location: Utrecht Posts: 4 |
Following this topic. Picking up my P400e in a couple of weeks. I hope that some manufacturer will come up with a solution for a rubber mat or a boot liner that will fit properly.
16th Apr 2024 9:07am |
I bought the one recommended by Metisse above. Very positively surprised. Doubt there is a better one out there.
I cut off about 1 cm on the left side for a perfect fit. Also used the cutouts for three of the tie-down points. It greatly diminishes the slope on all sides. Click image to enlarge Click image to enlarge 2024 Defender 110 p400e HSE 2015 Defender 110 Double cab 2004 Defender 90 Td5 Last edited by carltb on 16th Apr 2024 1:50pm. Edited 1 time in total |
16th Apr 2024 10:43am |
