Home > V8 > 3.9 on SUs - which cam? |
MercianRover Member Since: 07 Apr 2022 Location: Culworth Posts: 124 |
I ran the same setup and used the standard camshaft and BDR profile needles.
11th Apr 2022 2:53pm |
Ranger 6 Member Since: 17 Jan 2019 Location: Yorkshireman trapped in a Surrey postcode Posts: 187 |
Thanks - I have already switched to BBWs and it's made a massive difference to drivability.
My thinking is that a slightly improved cam will just give that extra 'spark' over a std one. 90 V8 CSW - 1988 |
29th Apr 2022 12:46pm |
Do you have the 3.9 exhaust setup?
Probably as well to get the distributor rebuilt and give the ignition system a refresh - Lumenition is another thing to consider. |
29th Apr 2022 3:28pm |
Yes, I have got the 3.9 exhaust on it already.
Does the electronic ignition really make that much of a difference? 90 V8 CSW - 1988 |
24th May 2022 4:02pm |
Leaning towards this one: https://www.v8tuning.co.uk/custom-ground-camshafts 90 V8 CSW - 1988
31st May 2022 3:01pm |
No more faffing around with points gap and suffering the results of vaiable condensor quality, just a consistent spark under all conditions. |
9th Jun 2022 2:09pm |
Thanks - I'll have a look at that when the engine gets built 90 V8 CSW - 1988
15th Jun 2022 5:22pm |
Ohlins Member Since: 20 Oct 2009 Location: French Pyrénées Posts: 28 |
My 3.9 on SU carbs has this one fitted...strong low end to mid range power.
https://crower.com/camshafts/land-rover/la...00cid.html https://crower.com/printcamcard/?part_num=55229&x=0&y=0 All the best . Army 110 3 Door 200tdi Army 110 3 Door V8 Army Lightweight 2.25 Petrol 110 300tdi 5 door Yamaha XT660Z Ténéré Gas Gas 300EC Ohlins |
5th Dec 2022 5:11pm |
Red line is pretty low on that Crower cam, admittedly the Rover V8 isn't great at high engine speeds but 4500rpm?
5th Dec 2022 5:24pm |
Indeed, though I must say I don't find it lacking in the low box and in high it cruises along just nicely. As you say these old pushrod two valve engines shouldn't work too hard...having said that my previous work V8's never died no matter how badly we treated them!!!
This is my first Defender V8/LPG with the engine installed as is when I bought it so I'm keen to learn about it over this winter. All the best . Army 110 3 Door 200tdi Army 110 3 Door V8 Army Lightweight 2.25 Petrol 110 300tdi 5 door Yamaha XT660Z Ténéré Gas Gas 300EC Ohlins |
7th Dec 2022 10:23am |
Thanks - all useful info
The engine is still waiting assembly as the house renovation came first 90 V8 CSW - 1988 |
19th Jan 2023 3:10pm |
