Home > V8 > V8 Soft top and fumes |
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 621 |
I get some fumes being drawn back in with just the back rolled up. Juggling the dash vents and cracking a window makes it better. With the sides up I don't get any fumes, or with a mesh top, or bikini.
By comparison it didn't happen when it used to be a Turbo D - until the day the exhaust tailpipe fell off the rear silencer! I've considered a fume curtain, but I prefer to let more fresh air in Click image to enlarge Click image to enlarge JB @Lodelaner Instagram Youtube greenlaning and other LR related content |
22nd Mar 2022 11:56am |
Not that I notice rolled up - it makes a pretty good seal. JB
24th Mar 2022 12:03am |
gbmoto Member Since: 06 Jan 2010 Location: West Sussex Posts: 21 |
Mine is OK, has a standard 3.5 exhaust sticking out the side.
Click image to enlarge |
28th Mar 2022 11:12am |
Van Diesel Member Since: 12 Oct 2013 Location: Suffolk Posts: 174 |
Very nice! 21 Defender D300 H/Top
63 FFRR SDV8 86 90 Pick Up 3.9 V8 |
28th Mar 2022 8:59pm |
Ranger 6 Member Since: 17 Jan 2019 Location: Yorkshireman trapped in a Surrey postcode Posts: 187 |
I'm ex-Army and old enough to remember when all the green Land Rovers were soft tops.
With the back rolled up there was always a whiff of fumes. It's the aerodynamics that the entrance is a low pressure area which sucks the air in - not an indication of a state of the engine 90 V8 CSW - 1988 |
30th Mar 2022 3:59pm |
Seeing as theres a few soft top owners posted on this thread just wondering about legality of rear seats in the 90?
Mine doesn't have any (yet). If I was to fit some, would it pass the MOT. Rear seat belts obviously needed although I'm sure I've seen some without? |
26th Mar 2023 12:36pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16943 |
It is the reason that the dash vents were introduced, you will always gets fumes sucked in the back (it is also why the back of a proper Land-Rover /Defender gets covered in crud). I think it is also why the vents were deleted - full soft-tops were no longer a factory option in the Puma era, as far as I know. |
26th Mar 2023 12:55pm |
Rear seats would be entirely legal as long as they are of the type appropriate to the age of the vehicle and are fitted as factory fitted seats would have been. You would be well-advised to let your insurance company know, of course. The fact that it is a soft-top has no direct bearing on the fitment of seats (unless the seats require the presence of a hard-top in order to be fitted, e.g., part of the seat belt mechanism has to be bolted to the upper structure). |
26th Mar 2023 12:58pm |
Whilst full soft-tops weren't a factory option in the UK, they were in other markets and the last of the line was produced as a soft top. I think the vents were deleted merely to accommodate the later dash as LR seemed to have lost their way with regards pragmatic design in the Puma era. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
26th Mar 2023 1:21pm |
Yeah, makes sense. I'm sure I've seen some of the rear side seats with just lap belts too? |
26th Mar 2023 1:31pm |
MercianRover Member Since: 07 Apr 2022 Location: Culworth Posts: 124 |
I sometimes get fumes drawn into my 100" Bowler when the rear curtain is rolled up - usually only on the overrun when exhaust pressure is low and sometimes at lower speeds if there is a crosswind. I have no dash vents to push air into the cabin. The exhaust is on the RH rear corner angled to put the gases out to the side in a similar manner to a series vehicle. |
27th Mar 2023 8:58am |
