Home > V8 > V8 in the muck |
gbmoto Member Since: 06 Jan 2010 Location: West Sussex Posts: 21 |
Slightly less arty farty pic
Click image to enlarge |
21st Feb 2022 9:57am |
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 621 |
Nice!
That exhaust tailpipe looks mighty narrow for the engine you have in it. JB @Lodelaner Instagram Youtube greenlaning and other LR related content |
21st Feb 2022 10:26am |
Thanks Lodelaner, it is a standard early V8 tailpipe, but agree, pretty small.
It did have a larger bore straight through pipe, which sort of sounded good but the novelty wore off pretty quickly, especially as it is often around horses! It is now standard early 90 end to end so would be for a 3.5 on carbs, not a tweaked 3.9 efi! But it has smoothed the power out nicely, much more driveable. |
21st Feb 2022 10:36am |
Totally agree - I'm not a fan of noisy exhausts at all.
I've got the Td5/TDCi centre and tailpipes, makes a nice woofle with no drone. JB @Lodelaner Instagram Youtube greenlaning and other LR related content |
21st Feb 2022 10:42am |
Doing a bit more chain harrowing saturday, mostly raising dust.
One small bit was very boggy so skirted around...so I thought....harrows sank and I stopped...slightly downhill too. In the end had to detach the harrows, get out with mucho 3.9 mud slinging, then use the towrope to recover the harrows, which took quite a tug. Once I detached them noticed how much mud I had slung! Click image to enlarge A loooong jetwash session underneath....and it's still dropping off! |
28th Mar 2022 11:17am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10545 |
That is a great pic 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
30th Mar 2022 8:46pm |
Ta Clayton, at one stage I thought I was going to have to call in the wife and her Jeep to tow me out
31st Mar 2022 8:09am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7876 |
I might be biased but thats a great looking Ninety! James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
1st Apr 2022 12:53pm |
Glad you got out and you didn't have to get the wife to pull you out 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
1st Apr 2022 8:26pm |
nicam Member Since: 14 Dec 2007 Location: deepest Lancashire Posts: 156 |
Occasionally do the same, using my V8 Lightweight to chain harrow if it is out and about and the tractor is away.
It is the hardest work going, as you are, effectively, towing hundreds of little anchors and it always strikes me how a 220Hp V8 can make it sound like a struggle whereas 24 HP of tractor makes easy work of it. Just shows what the right gearing can do!! Don`t drive faster than your angel can fly! |
23rd Sep 2022 4:10pm |
