Home > Orders 2022MY (L663) > 90 V8 Confirmed! |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1337 |
Looks like I was wrong , if you check the fitting instructions it looks like you have to drill into part of the sill for the front ones, I only watched him install the rear ones
Fitting instructions are here http://accessories-instructions.landrover....r/G2409773 http://accessories-instructions.landrover....r/G2409774 Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
30th Mar 2022 2:21pm |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 251 |
That’s great, thanks Ian!
Ooh, just saw your second reply. So potentially into metal then. |
30th Mar 2022 3:53pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7876 |
Looks fantastic!! When I first saw the V8 exhausts, I thought they'd look better with mudflaps. Your photos confirm it for me. James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
22nd Apr 2022 10:17am |
Now that you mention it, I agree!
22nd Apr 2022 12:34pm |
billewizz Member Since: 16 Sep 2011 Location: north lincs Posts: 66 |
What a belter
22nd Apr 2022 6:59pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3755 |
Hello Nick, from Aussie, the land of the V8.
LOVE your V8 90, particularly the exhausts. The V8 has been released in Aussie, but at a fairly astronomical price, $203K + on road costs, registration & stamp duty etc, + whatever options are specified. But, whatever the costs, I'm absolutely sure it's worth every cent. Congratulations, Pickles. |
22nd Apr 2022 11:56pm |
Thanks for the comments guys!
Really liking it as I get to know it. Did have to fix a rattle at the back though. The flap that covers the emergency triangle was a little loose so added a few adhesive felt strips, same as they use in the factory it seems. So far so good. First motorway trip today to Devon. Will be playing with the ACC as I haven't had that in a car before now, only standard cruise control. |
23rd Apr 2022 7:07am |
Hope you got your wallet!!
Safe journey! James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
23rd Apr 2022 1:27pm |
Kevantlin Member Since: 19 Jan 2020 Location: Lancaster Posts: 32 |
What MPG did you get down to Cornwall ?
Lovely car btw |
1st May 2022 11:49pm |
Only to Devon this time, but between the first two tank fills it was 241 miles at 20.1mpg, actually a little better than I was expecting. Most of that was motorway cruising and when possible in the 70's mph. I'm a believer in running in so very light throttle at the moment, not using ACC/CC up the steeper inclines, etc. Still only 450 miles on the clock but later this month will be doing a trip to Austrian Alps.
2nd May 2022 5:50am |
Thanks for your reply, that’s not bad at all actually! That won’t be that far off the p400 or even p300, I imagine when your right foot gets heavier it will be a different story.
Am I understanding you correctly, are you saying that from empty the tank only have a range of 240 miles ? |
2nd May 2022 9:22am |
No, currently a full tank shows a range of about 350 miles. To get that first consumption calculation I ignored the first full tank, as there was a lot of engine running on tickover during the handover process etc, but then took the mileage at the next top up back to full and again at the next top up. That was the 241 miles between fills that were not complete tank fills from empty. Hope that makes sense? Rather than rely on the car's computer I feel that taking mileages at each fill gives a more accurate figure. I use Fuelly to record the data so that will grow over time to give an average consumption with a mix of journey types and distances.
2nd May 2022 9:58am |
I have placed an order for one, probably an 18 month wait ? I figure the higher running costs are a good enough trade off against the smile/feel good factor.
Currently in a D240. Does the manual actually advise you to run it in ? |
2nd May 2022 12:17pm |
Might get less than 18 months as supply chain eases, maybe…..
Yes, in the iGUIDE, useful reading while you wait, under ‘Maintenance’. Click image to enlarge |
2nd May 2022 4:58pm |
