Home > Wheels & Tyres (L663) > BF Goodrich AT KO2 265/60/20 |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2729 |
New tyres finally arrived & fitted… really happy with them.
A tad taller and a tad wider than the standard 255s, but no clearance issues at all. And not worried about the sidewalls like the Goodyear Wrangler ATs which seem to be really prone to issues. Think the car sits really nicely on them too. Click image to enlarge Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
17th Jan 2022 6:37pm |
Buz1500 Member Since: 07 Jul 2020 Location: Cumbria Posts: 146 |
Any changes in road noise or ride quality since you’ve fitted your BFGs?
18th Jan 2022 9:01am |
Certainly there will be a little more noise than the road tyres I have had on for the last few weeks, but nothing like as bad as the Duratracs or other mud terrain-style tyres. I’ve always run BFG ATs on my old defenders and always thought they’ve been a good compromise.
If anything, slightly wider and taller tyres should help the ride quality a bit, but no real noticeable change. Should be a big improvement off-road where I’ll be happier airing down a bit if needed. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
18th Jan 2022 12:38pm |
stng110 Member Since: 04 Jun 2021 Location: Melbourne Posts: 102 |
Hi David
Any problems with rubbing when in access mode and turning the wheels hard left or right? Simon |
26th May 2022 8:59pm |
Not noticed any! Cheers, David
26th May 2022 9:46pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5028 |
How out is the speed now, I've toyed with fitting these but don't want the miss read Mike
29th May 2022 10:54pm |
You can use any of the online calculators; but it’s only small, about +1.9% from memory. Certainly not noticeable and probably if anything just correcting for the slight ‘under read’ from factory. Cheers, David
30th May 2022 11:59pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
I have the same BFG’s on mine and the speedo is about 1-2mph below gps measured speed👍
6th Jun 2022 1:25am |
Strictly, the error will be a % not a mph number. The 1.9% increase in rolling radius would translate to around a 1.4mph ‘under-read’ at 70mph and a c.0.7mph ‘under-read’ at 35mph.
I wouldn’t have thought that would even be enough to fully cancel out the usual built in ‘over read’ on the speedo but haven’t checked it against GPS myself. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
7th Jun 2022 11:11am |
mopadzi Member Since: 24 Sep 2013 Location: orlickoustecko Posts: 40 |
Monotube projekt (Germany) off road whells + BFG KO2 AT 265/60R20
Click image to enlarge Click image to enlarge |
5th Sep 2022 1:11pm |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 516 |
damn those look better. I just fitted 275/55/20's but those look much better with the slightly higher sidewall. My compromotives dont fit the new D300 due to the rear brakes and as its only got 400kms on it I am not brave enough to take the grinder to it yet.
Click image to enlarge "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce 11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
24th Nov 2022 7:41am |
