Home > In Car Electronics > Wire to extend switches |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19661 |
I think there is pre made looms you can buy that have appropriate wires and plug / sockets already fitted.
I’m not sure who though, but I’m sure there is such availability. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
7th Jan 2022 11:53pm |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 744 |
The forum shop sells them, switch extenders Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
8th Jan 2022 12:44am |
Looks like forum shop for cables etc is offline at present due to the semiconductor issue around the world
But you have them here also https://www.mudstuff.co.uk/products/defend...ions-loom, also on the bay of evil you can get the blank connectors etc if you wanted to make up your own Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
8th Jan 2022 12:50am |
pilsburypie Member Since: 19 Jul 2021 Location: Birmingham Posts: 173 |
Thanks for the info, but I was rather thinking of just purchasing a load of correct gauge wire (which is?), cutting the original wiring in the middle and soldering an appropriate length of wire in. Sure this is a faff, but with the nice and easy mud stuff plug and play extensions being £36 a pop, that’s £180….
8th Jan 2022 2:05pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16943 |
Does anyone know of a source of the male connectors used on those extension harnesses? The bit that the original connector plugs into instead of the switch.
I'd be grateful for a link or similar. Many thanks. |
8th Jan 2022 2:21pm |
Blackwolf no idea prob some place in the Far East.
Pilsbury pie you may not need to extend them all, I actually needed zero after buying one, as I could put the switches in other locations Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
8th Jan 2022 2:35pm |
Pic will help
8th Jan 2022 2:46pm |
Niels906 Member Since: 04 Jul 2020 Location: Bussum Posts: 44 |
Hey everyone,
I'm about to order the double din unit from defender upgrades.co.uk. Any one have any pictures as to the wire situation? Would be nice to know what I'm about to get myself into Thanks, Niels |
21st Jan 2022 2:36pm |
I fitted mine without any need for extensions, just moved switches to locations they would reach. Searching for my first Defender...and started just as Covid hit, so talk about timing.
21st Jan 2022 2:50pm |
I would ask PaulMC on here regards connectors, along with Martin they are both very knowledgable about them..
Some of the connectors are unique and are quite difficult to identify. PaulMC has kindly helped me many times for connectors and wiring items. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
21st Jan 2022 3:19pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6491 |
5 pin extension
Click image to enlarge I developed the 5 pin socket for this as there's no available matching connector for the plugs. Hazard extension Click image to enlarge 1988 90 Td5 NAS soft top 2015 D90 XS SW |
21st Jan 2022 5:17pm |
ant. Member Since: 14 May 2016 Location: staffordshire Posts: 6 |
Ate the switch extenders still available?
I need two 5 way and the hazard one |
10th Dec 2022 6:31pm |
I've got another batch of the 5 pin sockets due any day. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
10th Dec 2022 6:32pm |
Thanks Martin...will they be in the shop?
I need them for heated screens, front and rear. Presume all the same? No hazard switch ones? Dont mind extending one switch though... |
10th Dec 2022 6:46pm |
