Home > 130 > Another 130 |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 721 |
Click image to enlarge Congrats, looks very similar to my western power 130 when I got it, nearly 3 years ago now.. Keep us posted.. Cheers alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
11th Nov 2021 1:40am |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3467 |
The golden years of Defender. Used to see them all around heading to work and looking used but loved. Now it’s Toyota pickups hat have taken that marketplace and LR gives the people what they want 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
11th Nov 2021 8:55am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7711 |
Nice, I converted mine with hard top rear, still Impressed with its ability to load carry and carry people in comfort.
Click image to enlarge Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
11th Nov 2021 9:09am |
mwestcrew Member Since: 09 Dec 2019 Location: South Warwickshire Posts: 222 |
I’ve got an ex-SSE 130 pretty much identical, even has VO61J** reg no.
Have you worked out the electrics yet? Had mine two years and there’s still a button that I don’t know what it does. One of the first jobs I did was pulling out the hydraulic system. I was never going to use it and it removed a huge amount of weight. Mine has been faultless (apart from all the body rattles and squeaks) Click image to enlarge 2011 130 Utility Body 2005 110 Van |
11th Nov 2021 12:26pm |
Although on a second look at yours I don’t see the hydraulic spool outlets on the bumper. 2011 130 Utility Body
2005 110 Van |
11th Nov 2021 12:28pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7876 |
So want a 130! All look great! James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
11th Nov 2021 8:51pm |
Skeggy 90 Member Since: 07 Oct 2013 Location: Skeg Vegas Posts: 232 |
That’s what my one will look like after stripping the top layer of blue paint off to reveal the green. Takes ages I had to do that in my 110 I know what you mean about the buttons not sure what the one on top that makes a clicking noise does. Have you got an inverter on yours and mine hasn’t got the hydraulics. 90 300 TDI SW (sold) 130 TD5 Utility (Foley SV) (sold) 110 TD5 Hardtop (sold) 110 TDCI Utility (sold) 1st Edition Range Rover Sport Supercharged Velar P380 HSE Discovery 1 V8 auto Puma 130 Double Cab (sold) R35 GTR Defender 110 300 TDI CSW (sold) 2010 110 XS Utility |
11th Nov 2021 9:21pm |
Has yours got second row seats or is it stripped out in the back. 90 300 TDI SW (sold) 130 TD5 Utility (Foley SV) (sold) 110 TD5 Hardtop (sold) 110 TDCI Utility (sold) 1st Edition Range Rover Sport Supercharged Velar P380 HSE Discovery 1 V8 auto Puma 130 Double Cab (sold) R35 GTR Defender 110 300 TDI CSW (sold) 2010 110 XS Utility |
11th Nov 2021 9:24pm |
My old 110 SSC Click image to enlarge 90 300 TDI SW (sold) 130 TD5 Utility (Foley SV) (sold) 110 TD5 Hardtop (sold) 110 TDCI Utility (sold) 1st Edition Range Rover Sport Supercharged Velar P380 HSE Discovery 1 V8 auto Puma 130 Double Cab (sold) R35 GTR Defender 110 300 TDI CSW (sold) 2010 110 XS Utility |
11th Nov 2021 9:28pm |
Mine has an inverter and two additional batteries in the box body.
Big black button to left of heater controls connects auxiliary batteries to starter batteries while you hold it pressed. It’s to help start if you run the main battery low. I also have a red push button to the right of my heater controls and I still have no clue what that is!!!! I managed to work out how to remove the CAN bus interfaced speed limiter as Speedo 70 on the motorway was a real pain. There are so many electrical additions on mine, I am a bit nervous that one of the add ones is going to cause a problem in the future 2011 130 Utility Body 2005 110 Van |
11th Nov 2021 11:05pm |
Has yours got a reverse camera and one on the towbar. I could not get the tow bar camera to work on my 110 the reverse one worked fine. The 130’s drive much better than the other Defenders in my opinion but mini roundabouts can be a bit tricky. 90 300 TDI SW (sold)
12th Nov 2021 12:06am |
Mine was stripped out, bulkhead, Heater, inverter and battery.
I ditched all the wiring as someone had made a terrible job of removing/ ‘improving’ it, and since fitted rear seats on a custom seat base that I’ll put drawers in. Need to get the rear doors opening further, then fix the bodywork ‘triangle’ to the door for a nice square opening for the drawers. I can remove the seats pretty quick to put my fridge in How do you remove the speed limiter, the guy who mapped mine said it would be a box in the loom under the dash? I need to get in there for my heated seats/ screen wiring at some point, soon! 130s are the most comfortable Landy, and by far the best towing vehicle I’ve driven, love mine😀 Click image to enlarge Mine at the moment…. Cheers alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
12th Nov 2021 12:25am |
My speed limiter was interfaced to the canbus and was a stand alone device inside the drivers side seatbox. Mine was made by VDO I believe. You'll know it's the right box if it's there as it has a wire and lead seal. 2011 130 Utility Body
2005 110 Van |
12th Nov 2021 3:28pm |
Mine does have that system and before I tried to clean the main camera and killed it (!) you could swap between cameras using a button on the monitor, the only problem with that was it went back to the main camera if reverse was selected. Somebody told me in my research to find out what the big red push button on the dash that it swapped cameras. Have never made it work though 2011 130 Utility Body 2005 110 Van |
12th Nov 2021 3:39pm |
