Home > V8 > My V8 Swap (Toyota 1UZ-FE) |
Timbo Member Since: 15 Jun 2021 Location: west mids Posts: 135 |
The manifolds look the same as mine before I cut 3 bolt flanges off. I replaced them with 2 bolt. Smaller and easier to turn to the right position before welding. The 3 bolt wouldn't even fit in mine so I don't know how you managed that I would have thought the chassis rails were the same distance apart Looking good though mate I like the red gauges Citroen 2CV. (Written off)
66 Ford Mustang (Sold) Land Rover Defender 110 Hard top 300 tdi (Sold and subsequently written off) And a few BMW's before seeing the light |
27th Aug 2022 9:17pm |
LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 289 |
These manifolds fit well, just needed the flange fettling. The fact that they fit is porbably down to the box being smaller than your ZF one.
Was a bit risky at first with the red but its works well for me. Luke Marsden 06 V8 1UZFE Defender 90 Instagram: https://www.instagram.com/defender__v8/ |
27th Aug 2022 10:17pm |
Big noise clip:
https://youtube.com/shorts/J6n6OXu_aHs?feature=share Luke Marsden 06 V8 1UZFE Defender 90 Instagram: https://www.instagram.com/defender__v8/ |
6th Sep 2022 12:45pm |
I just realised why your flanges fit. Your engine is sitting higher than mine. Sounds lovely Citroen 2CV. (Written off)
6th Sep 2022 9:20pm |
Oh yeah, fair point. I better make sure prop angles are going to be ok then.
Will be finishing off the exhaust this weekend *touch wood* Will get a proper video of the car after that. Luke Marsden 06 V8 1UZFE Defender 90 Instagram: https://www.instagram.com/defender__v8/ |
7th Sep 2022 11:38am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3623 |
Where’s this video you promised us?!!
20th Sep 2022 5:49pm |
Thanks for reminding me Co1
This is all I got for now: https://youtube.com/shorts/Je7mX4U476g?feature=share Luke Marsden 06 V8 1UZFE Defender 90 Instagram: https://www.instagram.com/defender__v8/ |
20th Sep 2022 5:56pm |
That will do nicely thanks!
20th Sep 2022 6:06pm |
Well, the engine has got to come back out. For those that follow my instgram you will already know this but, it looks like the rear main seal has gone pop
So tonights task will be pulling the engine out and inspecting it. Does give me an opportunity to tidy a few lines and such up though. Got to look on the bright side afterall.... Luke Marsden 06 V8 1UZFE Defender 90 Instagram: https://www.instagram.com/defender__v8/ |
21st Sep 2022 1:57pm |
another positive Luke Marsden
21st Sep 2022 2:11pm |
oh no Citroen 2CV. (Written off)
23rd Sep 2022 9:16pm |
I know Tim, very sad.
it did only take me a couple hours which is the good bit but I'm waiting on the rear main to arrive now and then its going straight back in. Also tidied the interior up now so thats almost complete Click image to enlarge Click image to enlarge Luke Marsden 06 V8 1UZFE Defender 90 Instagram: https://www.instagram.com/defender__v8/ |
25th Sep 2022 11:19am |
Spent a bit of time finishing a few more interior bits, nothing major.
But look how sexy this is Click image to enlarge Click image to enlarge Luke Marsden 06 V8 1UZFE Defender 90 Instagram: https://www.instagram.com/defender__v8/ |
25th Sep 2022 7:27pm |
I'm no expert but do you know the reason the seal popped out? I would have thought that a pressure build up in the engine caused it? If this was the reason what could cause that? Have you considered this? As I say I'm no expert but just changing the seal may not be the answer. Citroen 2CV. (Written off)
25th Sep 2022 10:12pm |
